2016 rear axle code
Old Jun 8, 2018 | 09:28 AM
Daleford's Avatar
2016 rear axle code
I see a paper sticker on the rear housing of a 2016 F150, In large letters I see S878A Is this the axle code and is there a chart here so I can look it up? This is a burnt salvage truck and so the door tag is a gonner.
Old Jun 8, 2018 | 09:46 AM
No, that doesn't have the ratio.
Old Jun 8, 2018 | 09:55 AM
Daleford's Avatar
OK, how about another "code" I see near the Ford part number in smaller print:
8.8 EIPB
Old Jun 8, 2018 | 11:44 AM
The other way to find out is to jack up the truck, and get some chalk and mark the driveshaft and the rear wheel and start turning and counting.
Or get the VIN and ask a local Ford dealer.
Old Jun 8, 2018 | 11:53 AM
Daleford's Avatar
Thanks but I already talked to the dealer and I do know the ratio. What I am trying to find out if it is if it an electronically controlled differential.
Is there a visual check I can do for this?
Old Jun 8, 2018 | 12:02 PM
You can't tell any axle info from the VIN. The only axle info is on the door tag and the diff tag. You have a 8.8" axle there but "EIPB" doesn't return any useful info with a Google search. S878A is a fairly generic code that applies to several different configurations.
Old Jun 8, 2018 | 12:07 PM
Daleford's Avatar
So what does the "tag" look like and where is it usually located?
Old Jun 8, 2018 | 02:44 PM
It USED to be on a metal tag under one of the cover bolts.
