2016 vin check and fuel questions
Old May 4, 2017 | 02:35 PM
Daleford's Avatar
I buy and repair damaged vehicles. I am looking at a damaged 2016 F150 former utilities truck that has the following written on the tail board:
" powered by compressed natural gas"
Does Ford build them to run on this type of fuel from the factory or is this an add on aftermarket kit? Also wondering if it would still run on normal gasoline?
Vin, if it helps: 1FTEX1EF5GKE64601
The dealer can't help with a search as it comes up XXX - salvage.
Old May 4, 2017 | 04:23 PM
tcp2's Avatar
Enter the VIN in etis:
https://www.etis.ford.com/vehicleRegSelector.do
It lists all options for that vehicle. one of the options for this one is:
With Gaseous Fuel Prep Pack
ford does provide a dual fuel setup for fleet, I believe.
Primary Features
Build Date: 20.05.2016
Vehicle Line: F-150
Body Style: Super Single Cab
Version: 150
Engine: MOD 5.0L-4V DOHC SEFI NA
Transmission: 6 Speed Automatic Trans (6R80)
Drive: LHD 4WD (PTD)
Axle Ratio: 3.31
Emission: 50 State Emission Requirements
Air Conditioning: Manual Air Conditioning
Territory: (+)"USA"
Paint: Oxford White
Minor Features
Medium Earth Gray Interior
Front Door Scuff Plate - MIC
With Front Fascia - Level 1
Less Bed Divider
Decals - 4X4
My Key
With Conventional Tailgate
Less Tailgate Applique
Less Second Unit Body Covers
With 8' Styleside Box-Steel
Less Pickup Box Extender
Spray In Load Box Bedliner
Less Bed Ramps
With Base Payload Package
163"/4140MM Wheelbase
XL/Workhorse
(-) Version Packages
Kansas City Plant Build
Less Special Equipment Package
Less Exterior Dress Up Package
7000 LB. GVW
Less Appearance Group
F150 Sales Badge
Less Special Value Packages
Less Ambient Temp/Speed Pack
Feature Content Group 1
Flexfuel Sales Badge
With English Language Label
Owner Hand Book Pack
Less Water Wading Equipment
Less Tailgate Badges-2nd Level
Equipment Package 3
Less Outbound Modification Cnt
Less Fuel Label
With Power Front Windows
With Electric Rear Windows
With Solar Tinted Glass
With Fixed Rear Window
Less Heated Rear Window
Less Overhead Console
Less Floor Mounted Console
Less Floor Mat Kit
Fixed Foot Pedals
Interior Trim Accent Pack A
Less Front Floor Mats
Less Rear Floor Mats
Floor Cover - Vinyl Ins - Complete
Sunvisor Less Mirror - Drivers
With Sunvisor Mirror - Passenger
Running Boards - Platform Black
Grille - Moulded In Colour
Less Exterior Wheel Lip Moulding
With Black Belt Moulding
Less Side Auxiliary Step
With Dipping Rear View Mirror
Dual Power Mirrors-Manual Fold Back
With Black Exterior Mirror
Less Driver Seat Back Map Pocket
Less Passenger Seat Back Map Pocket
With Armrest
Less Rear Underseat Stowage Bin
Less Rear Seat Centre Armrest
Less Driver Seat Lumbar Support
Less Passenger Seat Lumbar Support
Less Multi - Contour Seats
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
Less Rear Heated Seat
2 Row-H/Ser Flip Up W/Cush/Bol
With Driver 2 Way Mnl. Seat Adjust
With Pass 2 Way Manual Seat Adjust
Less Trailer Towing
With Front Towing Hook
Less Trailer Module
Cleat Tie-Down Kit B
Exterior Door Handle - Black
Super/Super Single/Super Cab 4 Door
With Moulded Gearshift ****
Less Remote Controlled Tailgate Rel
Frequency - 315MHZ
Power Locks W/Auto Lock - Relock
Door Entry R/Cont Unit - Flip Key
With Remote Keyless Entry
With Variable Intermittent Windscreen Wiper
Less Sun Roof
Less Tu-Tone Accent Colour
Less Body Tu-Tone Paint
Front Bumper - Steel Argent
Rear Bumper - Steel Argent
With Front Licence Plate Bracket
Side Air Bag - 1st & 2nd row
With Standard Rear Seat Belts
With Steel Spare Wheel
Tyre Pressure Sensors - 315 MHZ
H/D Dual Front Shock Absorbers
Heavy Duty Rear Shock Absorbers
7.5 X 17 Steel Wheel
265/70R 17 A/T OWL
Spare Tyre-265/70R 17 A/T OWL
With Argent Wheel Hub Cover
With Capped Alloy Nuts
Less Assist Packages
Less Immersion Heater
Standard Electric Starter Motor
Less Remote Starter
Emission Compliance - USA
3.31
Less Elect Locking Differential
With 8.8 Axle
Single Exhaust
Less Exhaust Pipe Extension
With Mechanical Parking Brake
With 4 Wheel Disc-Brake
Less Brake Control Valve
Less Hill Descent Control
Normal Fuel Fill
Column Shift
Select Shift Tech (SST) W/Thm Swtc
Electric Trans Case With IWE'S
Less Skid Plates
With Single Fuel Tank
FFV-(Ethanol) Fuel
Steering Col-Man Tilt/Tele-Col Shf
With Locking Steering Column
Standard PUR Steering Wheel
Less Heated Steering Wheel
With Speed Control
With MPH/KMH Speedometer
Dual Note Electric Horn - Level 2
Outside Temp Thermometer
With Compass Display
MFD High TFT Screen
Less Navigation System
Customer Info Display-Package 2
With Reverse Gear Alarm
Less Speed Audible Warning Device
Less Blind Spot Information System
Less Lane Keeping Aid
Human Machine Interface 2
With Perimeter Anti-Theft
Less Rear Parking Aid
Less Automated Parking System
Less Power Convertor
Less Radio Reception Equipment
With NAAO Radio Frequency
ICE-Low Level CD + AM/FM Radio
Less ICE Noise Reduction
With 6 Speakers
Less Radio Subwoofer
With Media Gateway Module
Less Garage Door Opener
Less Smokers Package
Rear View Camera-Fixed
Less Specialty Packages
Less Auxillary Lights
With Level 1 Headlamps
With Daytime Running Lamps
Less Front Fog Lamps
Less Spot Light
Less Right Hand Spot Light
Less Lighting Packages
Less Interior Light Group
Tail lamps - Level 1
High Mounted Stp Lmp W/Cargo Light
Less Trailer Hook Up Light
With Auto Headlamp Plus Wiper
Oxford White
Generic Country Group 1
150 Series
FL34-5310-TA* L/F Coil Spring
FL34-5310-TA* R/F Coil Spring
FL34-5560-C* L/R Leaf Springs
FL34-5560-C* R/R Leaf Springs
F-150
(-) GVMT Service Administration
(-)"CDN"
(-) "Wallis & Futuna"
(-)"GU"
(-)"BRN"
(-)"BZ"
(-)"ATG"
(-)"NCL"
Old May 4, 2017 | 04:34 PM
Ford offered a "gaseous fuel prep package" from the factory, but the conversion itself would have been aftermarket, probably through a Ford-certified upfitter. It may or may not be still gasoline-capable, depends on whether it was a bi-fuel or dedicated CNG conversion.
Go here and enter the VIN, it shows that this truck did come with the prep package:
http://www.etis.ford.com/vehicleRegSelector.do
Old May 4, 2017 | 09:32 PM
Daleford's Avatar
Thanks for the info guys. I guess if I can't know for sure that it runs on gasoline I'd better stay away from buying it.
