Since I'm new here, just wanted to share some photos of my 2015 XLT with you guys. I've only had the truck a few months now (bought it January of 2016) and I've focused most of my upgrades on the lighting (naturally since it's what my company sells)
So far to date I've done the following:
Upgraded all rear lights to LED
Upgraded most of the front lights to LED (still have to do the blinker)
Installed LED High Beams/Low Beams/Fog Lights (I use a 6,000 lumen, 6,500k temp kit in all three)
54" AuxBeam Curved LED Light Bar on the top of the windshield
23" AuxBeam Straight LED Light bar just above my license plate frame
Dual 7" AuxBeam LED lights on the back of the truck for reverse
I'm also adding in 2 Baja Designs Squadron Pro LED lights to the front pillars once the weather clears up
Yeah... guess you could say I'm a bit crazy with the LED lights lol
Have you had any trouble with the holes drilled into the aluminum door jams? My shop is telling me slight vibration will cause the holes to enlarge, then result in corrosion, and have potential for light bar to fall. I have the light bar currently, but debating on pulling the trigger to drill holes for mounting it now that the shop is giving me negative feedback. What are your thoughts?
Very nice truck though! A good reason I want the light bar installed.
