frozen power locks?
Exactly why I haven't taken mine in yet. I suspect the actuators are not strong enough, and perhaps the aluminum being a better thermal conductor allows them to freeze.
I found this on another forum. There is a TSB for the door locks. Here is a list of know TSB's
Technical Service Bulletins:
TSB 15-0040
http://www.f150forum.com/attachments...tsb15-0040.pdf
FORD: 2015 F-150 – 3.5L GTDI - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH DTC P25B0 - BUILT ON OR BEFORE 3/6/2015
TSB 15-0041
http://www.f150forum.com/attachments...tsb15-0041.pdf
FORD: 2015 F-150 – COLUMN SHIFTER HIGH EFFORT OR ROUGHNESS - BUILT ON OR BEFORE 2/13/2015
TSB 15-0045
http://www.f150forum.com/attachments...tsb15-0045.pdf
FORD: 2015 F-150 – GLOVE COMPARTMENT CLOSES IMPROPERLY
TSB 15-0052
http://www.f150forum.com/attachments...tsb15-0052.pdf
FORD: 2015 F-150 – SUPERCAB/SUPERCREW CAB - FROZEN OR INOPERATIVE DOOR LATCH - BUILT ON OR BEFORE 3/25/2015
TSB 15-0072
http://www.f150forum.com/attachments...tsb15-0072.pdf
FORD: 2015 F150 – 3.5L ECOBOOST - MALFUNCTION INDICATOR LAMP (MIL) WITH DTCS P0060, P0161, P0157, P0054, P0137 AND/OR P0141
TSB 15-0073
http://www.f150forum.com/attachments...tsb15-0073.pdf
FORD: 2015 F-150 & Mustang - 5.0L DOHC ENGINES - COOLANT LEAK
TSB 15-0076
http://www.f150forum.com/attachments...tsb15-0076.pdf
FORD: 2015 F-150 - ORIGINAL FORD ACCESSORY TAILGATE LINER WARPED
TSB 15-0080
tsb15-0080.pdf
FORD: 2015 F-150 - SUPERCREW - REAR SEAT CENTER ARMREST DOES NOT STOW FLUSH WITH REAR SEAT BACK - BUILT ON OR BEFORE 4/27/2015
TSB 15-0081
http://www.f150forum.com/attachments...tsb15-0081.pdf
FORD: 2015 F-150 - WATER LEAK AT A-PILLAR OR AROUND WINDSHIELD - BUILT ON OR BEFORE 1/13/2015
TSB 15-0093
http://www.f150forum.com/attachments...tsb15-0093.pdf
FORD: 2015 F-150 - MULTI-CONTOUR SEAT - ADJUSTMENT OR MASSAGE FEATURE INOPERATIVE - SCMG AND/OR SCMH AIR PUMP CONTINUALLY RUNS - BUILT ON OR BEFORE 4/21/2015
TSB 15-0098
http://www.f150forum.com/attachments...tsb15-0098.pdf
FORD: 2015 F-150, 2013-2016 Fusion, LINCOLN: 2013-2015 MKZ, 2015 MKC - ONE OR MORE POWER WINDOWS - INTERMITTENTLY INOPERATIVE IN FREEZING TEMPERATURES
TSB 15-0102
http://www.f150forum.com/attachments...tsb15-0102.pdf
FORD: 2015 F-150 - ELECTRONIC PARKING BRAKE - PARKING BRAKE MALFUNCTION MESSAGE IN THE MESSAGE CENTER WITH DTC U3000 – BUILT ON OR BEFORE 2/21/2015
TSB 15-0115
http://www.f150forum.com/attachments...tsb15-0115.pdf
FORD: 2011 - 2015 F-150 – 2015 Expedition, Transit, LINCOLN: 2015 Navigator - 3.5L GTDI WITH DTCS P0234 AND/OR P0299 - DRIVABILITY SYMPTOMS
This article supersedes TSB 15-0107 to update the Service Procedure.
TSB 15-0131
http://www.f150forum.com/attachments...tsb15-0131.pdf
FORD: 2011-2015 F-150 - 3.5L GTDI - COLD START - TICKING/TAPPING OR RATTLE TYPE NOISE - BUILT ON OR BEFORE 5/29/2015
TSB 15-0140
TSB 15-0140.pdf
Superseded by TSB 15-0154
TSB 15-0142
TSB 15-0142.pdf
FORD: 2015 F-150 – Harsh or Firm 5-4 Downshift
TSB 15-0147
http://www.f150forum.com/attachments...tsb15-0147.pdf
FORD: 2015 F-150 – KING RANCH/PLATINUM/LARIAT - DRIVER'S SEAT CUSHION COVER LOOSE OR WRINKLED MATERIAL
TSB 15-0153
MYFORD TOUCH/MY LINCOLN TOUCH - VARIOUS FUNCTIONAL CONCERNS - BUILT ON 9/8/2015 AND THROUGH 9/26/2015
FORD: 2015 F-150 - Taurus, 2016 Explorer, F-250, F-Super Duty, Fusion & LINCOLN: 2015 MKS
TSB 15-0154
http://www.f150forum.com/attachments...tsb15-0154.pdf
FORD: 2015 F-150 – LARIAT/PLATINUM/KING RANCH - CLIMATE CONTROLLED SEATS - FRONT SEAT BACKRESTS LACK OF COOLING PERFORMANCE
The article supersedes 15-0140 to update the Title, Issue Statement and Service Procedure
Tsb 15-0171
http://www.f150forum.com/attachments...tsb15-0171.pdf
2.7l gtdi - mil illuminated with dtc p2450 - built on or before 10/5/2015
TSB 15-0182
http://www.f150forum.com/attachments...5-0182.pdf3.5L GTDI WITH DTCS P0234 AND/OR P0299 - DRIVABILITY SYMPTOMS - ENGINE BUILD DATE ON OR BEFORE 2/28/2015
(This TSB supersedes TSB 15-0115)
TSB 15-0183
http://www.f150forum.com/attachments...tsb15-0183.pdf
2.7L GTDI LEAKS ENGINE OIL – BUILT ON OR BEFORE 7/1/2015
TSB 15-0193
http://www.f150forum.com/attachments...0193.pdfAnalog
Speedometer Needle Sticking And/Or Incorrect Speed Indication - - Effective Dec 16 2015/ Built On Or Before 8/31/2015
Recalls:
Recall Number: 15V279000
Recall Date: 05/12/2015
RCONL-15V279-7467.pdf
Component: STEERING
Problem Summary: Ford Motor Company (Ford) is recalling certain model year 2015 Ford F-150 trucks manufactured March 19, 2015, to March 30, 2015. The affected vehicles may have been built with a steering upper intermediate shaft that was improperly riveted.
Consequence: If the intermediate shaft was improperly riveted, it could separate from the intermediate shaft flex coupling, resulting in a loss of steering control and increasing the risk of a vehicle crash.
What Owners Should Do: Ford will notify owners, and dealers will inspect the intermediate shaft and replace it, as necessary, free of charge. The recall began on May 22, 2015. Owners may contact Ford customer service at 1-866-436-7332. Ford's number for this recall is 15S17.
Recall Number: 15V251000
Recall Date: 04/28/2015
RCONL-15V251-7642.pdf
Component: STRUCTURE: FRAME AND MEMBERS:UNDERBODY SHIELDS
Problem Summary: Ford Motor Company (Ford) is recalling certain model year 2015 Ford F-150 vehicles manufactured January 30, 2015, to January 31, 2015. The affected vehicles may have loose or missing underbody heat shields.
Consequence: A missing under body heat shield can lead to degradation or melting of the fuel or vapor lines, increasing the risk of a fire.
What Owners Should Do: Ford will notify owners, and dealers will inspect the vehicle for missing underbody heat shields and fasteners, and will install the missing components as required, free of charge. The recall began on May 13, 2015. Owners may contact Ford customer service at 1-866-436-7332. Ford's number for this recall is 15S12.
Recall Number: TBD
Recall Date: 9/30/2015
Component Adaptive Cruise Control for Ford F-150
Ford is recalling some 37,000 2015 Ford F-150 pickup trucks for a potential issue with the adaptive cruise control. The company said that when passing "a large, heavily reflective truck," the radar in the adaptive cruise could incorrectly identify the truck as being in the F-150's lane of travel. The F-150 could then automatically apply the brakes until the adaptive cruise system no longer believes this to be the case. Ford said it received a report of one accident related to this issue. No injuries were reported. The recall affects certain 2015 Ford F-150 vehicles built at Dearborn Truck Plant, March 18, 2014 through Aug. 5, 2015, and at Kansas City Assembly Plant, Aug. 11, 2014 through Aug. 6, 2015. It includes 36,857 trucks in North America; including 33,481 in the U.S. Dealers will update the adaptive cruise software at no cost. Ford's number for this recall is 15S29.
TSB 15-0040
TSB 15-0041
TSB 15-0045
TSB 15-0052
TSB 15-0072
TSB 15-0073
TSB 15-0076
TSB 15-0080
tsb15-0080.pdf
TSB 15-0081
TSB 15-0093
TSB 15-0098
TSB 15-0102
TSB 15-0115
TSB 15-0131
TSB 15-0140
TSB 15-0140.pdf
TSB 15-0142
TSB 15-0142.pdf
TSB 15-0147
TSB 15-0153
TSB 15-0154
Tsb 15-0171
TSB 15-0182
TSB 15-0183
TSB 15-0193
Recalls:
Component: STEERING
Recall Number: TBD
Jbabs contact issue
I'd like to welcome you to the site as well, Jbabs. Heading to the dealership is definitely the best next step. I'll offer you the same assistance that I have to the other folks on this thread; PM me your details, and I'll arrange for your regional customer service manager to reach out. When writing, please include your full name, best daytime phone number, VIN, current mileage, and servicing dealership.
Crystal
Crystal
Thank you
I'm having the same issue. Only minus 11c and passenger locks won't unlock or lock. I don't think they actually locked last night when I parked and used the keyfob. Not sure about anyone else, but when I lock and lights flash, horn beeps.. I presume all doors are locked. Not true now.. passengers doors remained unlocked which meant my truck was vulnerable to thieves. Will have to physically double check them now.. defeats the purpose of remote entry. What's Ford going to do about this? It's also a safety issue for Kids in the back seat if owner doesn't realize this is an issue and thinks the doors are locked when they aren't. FORD needs to fix this ASAP... a recall or something. I will contact the dealer but this is a real pain to have to deal with on a brand new truck. Oh well, could be worse I guess.
doors
pita
Ive had my 2015 crewcab sport in 3 times for service... they say they are waiting for parts now.
rear passenger door will not unlock, open, with either handle or from inside or outside.
rear driver door will not lock..unless you press manual button down to lock it.. then it wont unlock with key fob.
real fun when you have three year old that has to sit in back with car seat...
I came out this morning, it was 3 degrees, and I couldn't get either of my kids in the back doors. I had to have my 6yr old climb through from the front to unlock one. I guess it's time to go to the dealership.
Crystal
pita
How long have you been waiting on the parts?
Send me a private message with your VIN, odometer reading, full name, phone number, and name of the dealer where the parts are on order. I'll see what I can do to speed up the process.
Thanks!
Mathieu
Click on her username (FordService) in the upper left corner of any of her posts, select private message from the dropdown.
Frozen Door Latch and Locks
New to the forum and thought I would comment on my experience on freezing weather and my F150 door issues. I have had issues with my driver’s side door not latching once I got in the truck. I’d open the door, get in and go to close it and door would not latch. Door has done this twice now. When this occurred the lock indicator appeared not to be cycling when trying to lock and unlock. (Lucky I have a video of the second occurrence) The first time it occurred it was 27 degrees and the second it was 17 degrees.
I have contacted my dealership and they want me to bring the truck in and drop it off, I’m just trying to align my schedule to take it in.
Thanks for the quick reply, Mpkav. Send me a PM with your details, and I'll get this escalated to your regional customer service manager. In your message, please include your full name, best daytime phone number, VIN, current mileage, and servicing dealership.
Welcome to the forum, TNJack; I'm glad you've already been in touch with your dealer about this. How many miles are on your truck?
Crystal
Crystal
Hi TNJack,
I'd like to offer you the same assistance that I have to others. PM me your details, including your full name, best daytime phone number, VIN, current mileage, and servicing dealership; I'll push this up to your regional customer service manager and have them reach out.
Crystal
Crystal
