F150 3.5l v6 tivct ffv
Old Sep 6, 2015 | 11:26 PM
24pawprints's Avatar
Can anyone tell me what the max payload would be for this model truck? It has the 3.73 RR axle.
In the future we may be using it to tow a boat and it appears it will do fine trailoring a boat just fine. However its primary use would be as a work truck using the bed to haul materials. Our older 5.4 1/2 ton truck is a beast had no problem occasionally hauling 3500lbs!
I don't want to tear up this new 2015 truck up and would like to adhere to its payload limit but between the salesman and the confusing charts, I don't know what that number is? Thanks
Old Sep 7, 2015 | 08:20 AM
Wookie's Avatar
What cab and drive configuration are you looking at? This changes things up quite a bit.
Old Sep 7, 2015 | 08:50 AM
Bobf150SC50's Avatar
Pretty sure the max payload is stated on the drivers side door post decal. The one with the tire size and recommended air pressure.
wondering what max actually means?
is that the point the bed squats enough to rest on the axle or what?
Old Sep 8, 2015 | 07:28 AM
It's the supercab 3.5L V6.
Old Sep 8, 2015 | 07:36 AM
Thanks, will check inside the door. You'd think if it were that readily available the salesman would be able to answer your question? He pulled up the chart on the Internet instead?
And yes, bed squating on the axle was how my husband treated the old truck. I'm trying to educate myself on proper hauling so I can properly nag him to take better care of this truck. Thanks
Old Sep 8, 2015 | 12:47 PM
Wookie's Avatar
The internet chart gives an appropriate rating for that cab configuration. The sticker on the door is for that specific vehicle once all options are accounted for so both are technically correct. The salesman won't be able to access the door sticker until after the vehicle is into the build process.
To get a truck loaded to the bump stops you have to put about twice the rated load in it.
Old Sep 8, 2015 | 12:59 PM
Thanks for the info. We found one that fit our budget, didn't need the bells and whistles because it's just a work truck. I think we can manage with 1680 payload. He's thinking about getting a trailer instead for heavier loads as the 3.73 axle increased towing to 7400 lbs.
Old Sep 8, 2015 | 06:42 PM
Real world towing limit will be closer to 5000#. The 3.5 NA doesn't have much torque.
