Trying to Install Led light bar
Trying to install led light bar on my 2015 f150. It has max tow with factory 7 pin and BLIS system. Hard wire to the back of 7 pin connector. Problem when I do all functions of the light bar works but the dash register that a trailer is connected and it shuts off the BLIS system.
Thanks.
Thanks.
rewire it to your brake light wires.
Any time the truck sees power draw on the brake harness it will probably assume that a trailer is hooked up.
Unless someone else knows of another workaround????
thanks for the reply mkosu04. Hoping for a ez fix. Will keep looking.
WoodsTruck, it is a Partsam Universal White Red Truck Turn Signal Tail Reverse Tailgate 60" LED Strip Bar.
