2018 Ford F-150
Old 12-27-2017, 04:44 PM
LRSPaulP's Avatar
2018 Ford F-150
Does anyone know the easiest way to run a wire from the engine compartment to the cab on a 2018 F-150? Thanks for the help !!!
Old 12-28-2017, 12:34 PM
silvercreek's Avatar
If you're running only one wire there should be a few options on the firewall. Some people run the wire(s) under the cab and enter through one of several rubber grommets underneath. If you're running a 12 volt hot wire you need to take care not to allow the insulated part of the wire to rub against any sharp metal.
Old 12-28-2017, 12:39 PM
LRSPaulP's Avatar
Thank you. It is the on/off switch for the light.
Quick Reply: 2018 Ford F-150
