Issues
Issues
I have a 2009 f150 when I get over 45mph and try to Accelerate to say pass someone on the interstate it starts to sputter like a misfire. The CEL with blink then turn solid. Sometimes the code is for camshaft position sensor sometimes it will be cylinder H or E. I will clear dtc codes and go down the road floor it samething but no telling which code it will throw its never the same one. I looked at cylinder 5 which should be cylinder E and there is nothing wrong with the plug or coil pack and both are less than a year old. I changed crankshaft sensor did nothing. Prolly going to go ahead and change camshaft sensors next but looking for other ideas. Truck is just over 2k from being at 200k miles
p0346 misfire
p0316 which is an O2 sensor
2009 f150 5.4l
I ran seaseafoam help clean engine and injectors out.
P0135 is O2 sensor heater circuit. Sensor itself or wiring.
https://www.obd-codes.com/p0135
https://www.obd-codes.com/p0341
https://www.obd-codes.com/p0346
Is the engine quiet? If not and it's making noise you may need a timing job.
