P0353 misfire won’t clear
Old Sep 15, 2022 | 05:48 PM
Smartens82's Avatar
2010 5.4L throwing a p0353 code and running awful. Swapped coils and threw in new plugs and even new fuel injector . Problem still exists. Any help would be appreciated. Problem is still on cylinder 3.
Old Sep 15, 2022 | 06:51 PM
projectSHO89's Avatar
A P35x DTC is not a misfire code, it's a coil electrical circuit fault (which will cause a severe misfire). You have a circuit fault with the #3 coil. Probably a connector, wiring, or PCM problem.
Old Sep 15, 2022 | 06:58 PM
Smartens82's Avatar
Starting to think it’s the PCM. Everything else seems to check out fine. Wiring isn’t open. Was able to ping it out to pin 55. Have never swapped a PCM before. Is that something you can just replace ?
Old Sep 15, 2022 | 07:31 PM
You should have said that in the first place.
No. It requires programming, including PATS.
Old Sep 15, 2022 | 07:34 PM
Smartens82's Avatar
Old Oct 16, 2022 | 09:32 AM
Smartens82's Avatar
Update
Update: Replaced the PCM and all is well now. Thankful for forscan!
