2011 402k miles 3.5 Ecoboost cam phaser and timing chain repair cost
I have a 2011 F150 3.5 Ecocboost with 402k miles, I have owned since 18k. I am getting cam phaser noise on start up in the morning and fine the rest of the day. No codes, but want to see what average cost is to repair. Truck is otherwise in good shape and my daily driver.
I'm curious to know how often the oil changes were done? And if the engine ever needed the intake ports cleaned? And what other maintenance/repair the engine has required such as throttle body replacement? I've read elsewhere that the throttle bodys were a high maintenance replacement?
Oil changes every 5k miles and sometimes closer to 10k.
I live in Arizona.Plugs every 50k miles
Ignition Coils every 100k miles
Starter 188k and 344k
Water pump at 200k
Driver side precat O2 sensor at 210k
Oil Pressure sending unit switch 180k miles
Rear shocks at 180k and 354k miles
Front struts at 343k miles
Upper control arms at 343k miles
Used transmission and new flex plate at 353k miles ($2000 installed)
Drivers side lower ball joint at 354k miles
Passenger side valve cover at 352k miles (valve cover spark plug seals bad)
Headlight bulbs at 380k miles
PCV Valve hose 396k miles
Windshield washer pump at 400k
Hoses and belts a regular basis as needed
Pegasus Coolant Overflow tank hose mod kit
Brake pads and rotors as need. Autozone gold pads with lifetime warranty.
Tires as needed, I have never had a alignment on the truck.
Still need to do the rear diff fluid, its never been changed.
Factory radio died and replaced with after market
Water pump at 200k
