Misfire on cylinder 6
Old Jan 5, 2020 | 11:53 PM
Solonglater's Avatar
Hi I’m new to this group, I have a 09 Ford F-150 with 5.4 motor in it. It’s showing misfire on cylinder 6 , I replaced the cop with number 5 and put all new 8 spark plugs and still showing misfire on cylinder 6 , also put anew injector on that cylinder, what could it be, thanks in advance for your help
Old Jan 6, 2020 | 12:00 AM
Have you done a compression test? How many miles on the engine?
Old Jan 6, 2020 | 12:07 AM
Hi, it has 246k miles the I just replaced vct solenoids , guides , cam phasers sprockets,timing chains and compression is good
Old Jan 6, 2020 | 10:01 AM
Roadie's Avatar
Is the COP getting it's primary voltage signal? Is the injector getting its signal? sounds like those are the only two items left to check?
Old Jan 6, 2020 | 02:11 PM
Yeah I’m going to check with a noid light tester and see
Old Jan 6, 2020 | 07:04 PM
Dennis_461's Avatar
When did the misfire show up? After the work described here or before?
Do you get this code alone?
P0316 – Misfire detected on startup (first 1000 revs)
Old Jan 6, 2020 | 09:14 PM
hi it happens before and the code is p0306
