Intermittent Cluster Panel
Old Apr 14, 2018 | 08:57 AM
TJB2010's Avatar
Cluster panel shows low tire pressure and other errors.
Panel resets when you tap on the panel.
However the problem reoccurs at random.
I removed the panel cover and wiggled the connector, problem will go away. If you gently push on the connector the problem is back.
I wedged a piece of wooden shim between the connector and the panel, problem solved.
Eventually the shim moves and intermittent problem is back.
Can the wiring harness that connects to the cluster panel be easily replaced.
Old Apr 14, 2018 | 10:24 AM
What are you working on?
Old Apr 15, 2018 | 09:50 AM
They got a 2010 F150 XLT.
Old May 12, 2018 | 05:34 PM
Rr38690's Avatar
Had this same issue with my 2010. Dealer determined I need a new cluster. Replaced it and no issues since.
