PeytonRice |
07-28-2017 09:48 PM |
Your oil catch can will only catch the oil burn off from the heads that get fed back into the intake. This has nothing to do with the condensation build us in the IC. I have a UPR mega catch can from stage3motorsports. It works great, and easy install. You will be amazed of the crap you'll keep out of your motor. Definitely would recommend. As for the condensation in the IC, just remember the bigger you drill the hole, the more boost you'll lose. A small hole shouldn't make to much of a difference. Be careful aftermarket tunes, when I was on stock I never had an issue with condensation but with the new tunes, they ran the boost up for power but then it would pick water at high rev. Pissed me off so bad.!!
