2010 roof seal leak
Old Jun 25, 2017 | 01:28 PM
pagan696's Avatar
2010 roof seal leak
i had a difficult time searching for this exact problem on the forums so if it's been covered please move to or link to proper thread.
my 2010 fx2 roof seals above the rear window had started to crack and i have water leaks on both corners that allows water to enter the cabin area.
the seals look to be rivited on, and not sure if it's an easy to fix or something that needs the dealership or body shop to do.
what is the proper term for these seals? replacement easy to preform? if too much trouble will trim out old and reseal w premium caulk suffice? how would you recommend to clean the water stains on headliner?
thanks!
Old Jun 27, 2017 | 04:21 PM
wjfawb0's Avatar
My 2010 F150 has the same issue. I keep it parked in a garage most of the time, so it's not urgent at the moment.
