sunroof button question
My sunroof just had some work done on it. Prior to this work, one touch of the button would start the opening process. If I changed my mind while it was opening I'd just hit the "close" direction and it would stop, then I could hit "close" direction again and it would close the sunroof all the way. I'd also do this if I just wanted it partway open...you hit "close" where you want it to stop, then later hit close again and it would shut.
After the work has been done, that button process is hit or miss. The first touch still stops the motion of the window...but most of the time the second touch will simply make the window keep going in the "open" direction.
Has anyone had this issue? I don't know how the button could sometimes do one thing, and other times do something else. It makes no sense.
