Tire size question, thanks!!!
Hey everybody. I've been searching a lot on here and I'd really just like to be sure before I spend a grand or so on tires that I get the right ones. I'm a fan of Goodyear duratracs so I'll be going with those. My question is what is the largest tire size that I can go with on a stock 2013 4X4 XLT supercrew? Stock 18 inch rims will be used. Thanks!!!
Originally Posted by Rahusband
(Post 5190489)
1 Attachment(s)
Without doing any other mods to the suspension or needing to trim, it seems that you can go a size or 2 over the stock width number.. For example, if your OEM size starts out with "265", you can usually go to a "285" (and leaving the rest of the numbers the same) and be okay.. You'll still have to re-calibrate your speedo if that's important to you..
I think some have gone to even a "305" and been real close to rubbing, but okay for the most part.. I just spent about $1100 on these tires, but they are still the OEM size, but I really like this style of tire over the stock Bridgestones that came on the truck.. :) These are "Back Country A/T" from a local tire chain in my area and the stock 275/55/20 size. Attachment 2145 Good luck! Mitch |
Ok, so I got my truck leveled with a 2 inch kit. Now I'm just debating on 275,285 or 295/70 18. I really want to go with Goodyear Duratracs. Had them before and really liked them. Any opinion on these tire sizes anyone?
295s should fit fine with a 2" kit, that's what I ran on my 2013 XLT. The only times they scrubbed was when I would turn sharp at odd angles, like down a steep hill on the farm.
HELLO GUYZ. If i can chime in here. I have a 2013 supercrew XLT with 18" wheels. I put Bilsteins up front and raised it 1.5 inches. Was given a set of **** Cepek rims 17X9.
How big can we get under it without rubbing??? 35x12.50x17 ??? 315x70x17 ??? THANKS FOR ANY INPUT |
