Possible Braking Problem in 13-14 MY Trucks
If you think about it, this only occurs if you get a perfect storm of failures. Since there is no visible leak on the garage floor, the brake fluid is going somewhere. Most likely into the vacuum pump. If that's the case, the master cylinder is leaking, the brake booster is leaking, and possibly the low fluid level switch is failing. When you get all 3 failures, and your fluid level gets dangerously low, you get complete brake failure.
It is highly doubtful that the FLI is also failing. (Fluid Level Indicator switch)
Several of the complaints said the light came on and they ignored it.
More likely is the possibility that the leakage prevents the primary circuit from building pressure... perhaps as you try to build pressure it just "squirts" into the booster.
Either way - I'm 99% sure you still have secondary circuit brakes. Just push that pedal to the floor and push really hard.
Did not know that. Still until Ford figures this out, I'm telling everyone I know with a 13-14 150 to keep an eye on the fluid level.
But as you, I was shocked to learn this significant change in mechanical and engineering design took place mid-body style.
Apparently, MY '13-14 has an entirely different front suspension setup than MY '09-12, and is the basis for the front suspension in MY 2015+ (some say it's the exact same), so this may explain why this issue is specific to these years.
This would be totally different. (BTW - you mean that the check valve prevents the pressure from entering the Vacuum Booster, not the MC).
If the Vacuum Booster were pressurized by the turbos the driver would experience an extremely hard pedal. Not a soft pedal that goes to the floor.
I had a very scary experience last month with my 2011 Edge that is similar. My brake booster failed on top of a recent poorly done brake bleed and led to a near miss at an intersection. I was heading down a residential road that turned into a stepp incline. The brakes slowly faded into the floor and I wasn't going to stop in time. Thankfully, I threw it into Manual and geared down and then slammed parking brake once I slowed down and wasn't worried about skidding or spinning out. It worked well and I would suggest the same steps to anyone in a similar circumstance. As stated, you will have some braking. After going down the hill, the brakes weren't doing much more than slightly slowing up the Edge though.
The real kicker is that this happened only 3 days after I had it into the dealer for "poor braking". I found the TSB on the brake booster and even provided it to them. The tech said he couldn't find anything wrong and just bleed out the brakes and sent me home with a $200 bill. I wasn't too happy when I went back to the dealer.
That's not true. My 13 has the exact same setup as my 07 and 05 had. The change was on the 14's only, and it was the bottom of the strut mount. Everything else stayed the same.
