2012 Eco Boost MISFIRE
check plugs
I've been having this issue for awhile now, and really just decided to give up and live with it.
However now I want to trade in my truck, and the Dealer wants to deduct $2000, because of this misfire.
Basically when I punch it, the engine sputters and looses power. At times it has gone into limp mode until I slow down below 40. the engine light comes on once in awhile, sometimes it goes off, sometimes it doesn't.
I've heard everything form water in the Turbos, to faulty ignition coils, to the vacuum pump,(which I have already replaced).
I know there are many similar issues with other owners. Has anyone had a definite answer that fixes the problem?
For me I would not buy an EcoBoost again, citing, poor milage compared to advertised, engine issues, and overall poor performance.
I've been fighting a shudder problem with what seems like a misfire without any codes thrown...looked into a ton of stuff like condensation problems and oil catch cans...etc. No fix, finally I checked my plugs and found multiple plugs cracked, changing them tonight, hope that fixes my issues. Be a good thing to check on for anyone having shuddering with no codes thrown.
good luck!
Emissions Defect Warranty:
— 8 years or 80,000 miles (whichever occurs first) for catalytic
converters, electronic engine control unit (ECU), transmission control
module (TCM), and any other onboard emissions diagnostic module.
— 3 years or 36,000 miles (whichever occurs first) for all other
covered parts.
Emissions Performance Warranty:
converter, electronic emission control unit (ECU), transmission control
— 2 years or 24,000 miles (whichever occurs first) for all other
covered parts.
Boots would not be covered under the 8/80 emissions defect or performance warranty. If anything, they may launch a customer satisfaction program like they did for the 05 fuel injectors and recently, the Ecoboost vacuum pump.
covered parts.
covered parts.
It's TSB-14-0180
Engine Misfire Symptoms Accompanied by Diagnostic Trouble Codes (DTCs) P0300, P0301, P0302, P0303, P0304, P0305 and/or P0306 – 2011-2013 Ford F-150
TSB 14-0180
3.5L GTDI – ENGINE IGNITION MISFIRE – BUILT ON OR BEFORE 6/15/2013
The article supersedes TSB 14-0160 to update the base warranty causal part number.
ISSUE:
Some 2011-2013 F-150 vehicles built on or before 6/15/2013 and equipped with a 3.5L Gasoline Turbocharged Direct Injection (GTDI) engine may exhibit various engine misfire symptoms accompanied by diagnostic trouble codes (DTCs) P0300, P0301, P0302, P0303, P0304, P0305 and/or P0306 stored in the powertrain control module (PCM).
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Does normal diagnosis in the Powertrain Control/Emissions Diagnosis (PC/ED) manual lead to spark plug inspection?
Yes – proceed to step 2.
No – this article does not apply. Continue with normal diagnosis.
Remove the spark plug from the affected cylinder. Refer to Workshop Manual (WSM), Section 303-07.
Inspect the spark plug for signs of carbon tracking. Is carbon tracking evident? (Figures 1 and 2)
Figure 1 - 14-0180
Figure 1 – 14-0180
Figure 2 - 14-0180
Figure 2 – 14-0180
Yes – replace all six spark plugs and spark plug coil boots. Refer to WSM, Section 303-07.
No – this article does not apply. Refer to PC/ED manual for normal diagnosis.
PART NUMBER PART NAME
BL3Z-12A402-A Coil Boot (Req 6)
CYFS-12-YT3 Spark Plug (Req 6)
XG-3-A Motorcraft® Silicone Brake Caliper Grease and Dielectric Compound
WARRANTY STATUS
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage.
TSB 14-0180
ISSUE:
ACTION:
SERVICE PROCEDURE
Figure 1 - 14-0180
Figure 1 – 14-0180
Figure 2 - 14-0180
Figure 2 – 14-0180
WARRANTY STATUS
Okay - which exact warranty? 3/36 bumper to bumper, 5/60 powertrain, 2/24 emissions performance, 3/36 emissions defect, or 8/80 emissions? I don't see where that would qualify under the 8/80, it's not "catalytic converters, electronic engine control unit (ECU), transmission control module (TCM), and any other onboard emissions diagnostic module".
Ford F150 3.5L V6 Ecoboost Misfires: Spark Plug Replacement NEW GAP ON PLUGS!
Video changing your spark plugs.
also this too.
2013-2014 Ford F150 3.5L Ecoboost New Misfire TSB! TSB 14-0017 video
http://safeshare.tv/v/ss56d43160178a0
