2012 Lariat Aux Switches
I have a small LED behind the grille but tapped into the high beam circuit so I can use toggle switch (on-off-on) I have it set to be activated with the high beam, off, or switched on by itself. When running at night, it is nice that I can kill it by dimming the lights and I don't have to go hunting for a separate switch.
On mine, they are closer to the rearview mirror and part of the "plastic console" that holds your sunglasses and the overhead lights. The whole plastic console had to be pulled out to be able to drop the headliner, but could then be re-installed after I had the switched in place.
I found a guy on another forum making them. He can do 4 or 6 switches. he can also just make a blank. If you get the 4 switch version like mine, he will etch pretty much anything you want in the center. He can now also do plates for the larger "ARB" switches.
you have to cut out the headliner and then it mounts with screws, fender washers and nuts. If you have a moonroof, you have to cut a bit of headliner support plastic as well.
Very nicely made piece, it could pass as factory if installed clean enough.
If you're interested, shoot me a PM and I can send you his contact info.
