Help
Old Dec 10, 2015 | 02:04 AM
dballoujr's Avatar
Help
What is the biggest tire I can fit under completely stock 2010 f150 stx super crew 18 inch rims I have set of fierce mt 35 x 12.50 what would I have to do to run them and I can trim the front
Old Dec 10, 2015 | 08:05 AM
2008_XL's Avatar
Killer run-on sentence, man!
And, you didn't say if your truck is 2wd or 4wd. Either way, even if it's 4wd, I don't think they'll fit on a stock height truck. You'd need a 2-2.5" level on a 4wd truck. And even then, you may still have some rubbing.
A 33" tire is probably the most you can fit without a level. Again, that depends if you're 4wd.
