Rattle with cruise control
Old Jun 30, 2015 | 01:19 PM
HeyBob's Avatar
Registered User
I have a 2010 4.6 that has developed a weird rattle initially with cruise control.
You would set the cruise, after 5-10 miles you could hear this rattle that kind of sounded like detonation.
It has recently started doing it without the cruise as well. This morning it did it accelerating down an expressway ramp, without cruise.
I had a major tune-up around 85,000 miles, I am at 109,000 now.
It will stop immediately if there is any change in throttle position, such as accelerating or decelerating.
Anyone have any ideas? Been doing it for over two years, the dealership said they have no idea what it is.
I also have developed a hard shifting transmission. The trans when you kick it down during passing, shifts so hard you would think something broke inside. The dealer has pulled the pan, said there are no codes, everything looks good, has no idea what is wrong with it either.
Looking for suggestions.
Old Jun 30, 2015 | 01:43 PM
Does it rattle with premium gas?
4 speed or 6 speed transmission? 2 valve or 3 valve 4.6?
Did the major tuneup include MOTORCRAFT spark plugs?
Old Jun 30, 2015 | 01:46 PM
HeyBob's Avatar
Registered User
I never run premium gas. 6 speed, not sure if it's 2 or 3 valve. How do I tell?
I sure hope it did, I had the Ford Dealer do it. (plugs)
Old Jun 30, 2015 | 04:34 PM
If it's a 6 speed, it's a 3 valve.
TRY premium gas (93 if you can get it) for troubleshooting purposes - if it stops rattling, it's spark knock. That's usually caused by combustion chamber deposits, you may need a BG or Motorvac intake cleaning job. Or - it may have a bad knock sensor.
Go back to the dealer and have them research TSB's on the transmission. The 6 speed had a lot of software updates, quite a few of them to fix poor shift quality.
Old Jun 30, 2015 | 05:43 PM
HeyBob's Avatar
Registered User
They have re-flashed the transmission three times, said give it time to learn. Usually lasts only a few weeks. Then it's back to the hard shifting scenario.
Old Jun 30, 2015 | 07:41 PM
What kind of fuel are you running? Sure sounds like its pinging from crappy fuel. Maybe try to find a Shell or Chevron station and fill it up.
Old Jun 30, 2015 | 07:52 PM
HeyBob's Avatar
Registered User
I don't think it's spark knock. It almost sounds like a relay chattering.
I will try better gas next fill up in a day or two.
Old Jun 30, 2015 | 09:47 PM
One tank of 91+ will prove or disprove the spark knock theory.
Old Jul 1, 2015 | 08:59 AM
HeyBob's Avatar
Registered User
I am going try that, but as of this morning, I think it's mechanical, inside the engine.
As I was getting coffee and driving along side McDonalds, I could hear a lighter version of it.
Old Jul 1, 2015 | 10:24 AM
If you hear it in a drive-through, it may be cam phasers.
Old Jul 1, 2015 | 10:26 AM
HeyBob's Avatar
Registered User
For as much noise as they make, I am thinking you may be correct.
