2009 A/C quit working
Old Jun 3, 2015 | 05:25 PM
trirunner2071's Avatar
New to this forum and trying to determine whether I need to take it to the shop or a simple fix.
Last weekend on a long drive the A/C just quit working. Normally it blows super cold air and I need to keep it turned down. But on this 8 hour drive I found myself turning it up until it was full blast, which is unusual but I just assumed I was driving into the sun and getting warm from the direct sunlight. Anyhow, I realized that night the A/C just quit working.
I checked the A/C Fuse and A/C relay under the hood and both are good. Is there some place else I need to look, simple fix that I could do myself? I am mechanically inclined so I don't mind taking stuff apart to fix something.
Any help would be appreciated.
D
Old Jun 3, 2015 | 06:38 PM
It probably has a leak and you are low on refrigerant. If you don't know your way around auto A/C systems, take it in.
Old Jun 4, 2015 | 05:05 PM
Thanks. I just checked the pressure and it isn't low on refrigerant. Other than the fuse and the relay in the fuse box, is there something else that could be a simple fix before I take it in to get repaired.
