tailgate lock cylinder
Old Apr 14, 2015 | 05:12 PM
tbones's Avatar
Are the pins on the tail gate lock matching to the door lock? I use the tail gate lock daily. Today I inserted a padlock key into lock and it worked. Then I tried a small screwdriver to turn the lock, worked too. I sprayed wd-40 into lock to lube. Still works with anything. Seems like there is only 2 pins up and down. Any thoughts.
2010 f150 xlt.
Old Apr 19, 2015 | 08:58 PM
They should match the doors.
I would get a new cylinder.
Also, never use the WD40 in locks!
Old Apr 21, 2015 | 11:44 PM
dry graphite power to lubricate lock tumblers
My key works in the tailgate, never tried anything else?
I did swap my lock over when I swapped to my camera mount tailgate handle, its just held it by a large snap ring/cotter pin ring
Old Apr 28, 2015 | 10:09 AM
fordboyj's Avatar
yes sort of the same pinning the first three pins are for your gate the last 5 or so are for starting.
Old Jan 15, 2016 | 12:20 AM
Ace_boy2099's Avatar
yes, doors and tailgate all use the same lock cylinders and guts. Inside the cylinder is 6 pins (might be 5) split half up half down, when you insert the key it pulls the pins together into the code and let's it turn. I just re-keyed a cylinder for my tailgate conversion, hardest part is finding the guts.
