Baking tail lights
Old Nov 29, 2014 | 08:16 PM
Baking tail lights
Did some googling, havent found anyone that was successful at opening up factory 09-14 tails.
What's the scoop? Who has actually tried it? Good or bad?
Old Nov 29, 2014 | 08:33 PM
NASSTY's Avatar
From what I've read you have to cut them open. They aren't too expensive, I think I'd just buy a set of FX/Raptor tails for $120.
http://www.f150forum.com/f38/how-pai...lights-235178/
Old Nov 29, 2014 | 08:41 PM
errr wow,
I've been given a set to play with, maybe ill try and bake them and see what i can come up with
Old Nov 29, 2014 | 08:44 PM
NASSTY's Avatar
errr wow,
I knew my lazy negative attitude would inspire you to try it.
Old Nov 29, 2014 | 09:11 PM
MGDfan's Avatar
Searched eh?
Took 5 seconds...
BSB
Old Nov 29, 2014 | 09:46 PM
I should get another 10 dollar discount
Old Nov 30, 2014 | 03:49 AM
05RedFX4's Avatar
A few years ago I baked my tails on my 07 and broke one. Ended up having to buy another tail light, the stock tail assy was 5 bucks cheaper than a harley tail so I bought a regular one. I would of had to buy both if I went for the harley. Since you have a spare set to play with, try to separate them. But if you had to experiment on your tails I would just buy the harley/FX4 tails.
Old Nov 30, 2014 | 08:22 AM
MGDfan's Avatar
Here ya go. Mr. P.
==> https://www.f150online.com/forums/pa...ml#post5120458
Fer when y'all break the set you have trying to bake them and not simply cut them open.
Seriously - this appears to be a purty good deal fer fresh 2014 components.
Old Nov 30, 2014 | 12:38 PM
downfromthesky's Avatar
Originally Posted by MGDfan
Here ya go. Mr. P.
Thanks for the plug
Old Dec 19, 2014 | 11:36 PM
errr wow,
Well??
Old Dec 20, 2014 | 10:00 AM
03Fx4JD's Avatar
Guess I'll strike that from my list of things to do. I'm not cutting open tail light housings. Guess I'll just have to save some doe and buy the Fx4's.
Old Jul 19, 2015 | 08:40 PM
I opened them up last week, Totally killed the lenses in a bad way. I think ive got a system that will work after killing both lights I was given.
Just need to find another set to play with since I don't want to risk killing the tails on my truck and be out of commission......
Old Jul 20, 2015 | 09:58 PM
aviduser's Avatar
I cut mine open with a soldering iron. Was able to weld them back up after, then just a bit of silicone for good measure.
Unfortunately I was rubbing some polish off a week later and somehow cracked one. I ended up buy a new OEM set off ebay.
