Too much oil?
Old Apr 6, 2014 | 07:01 PM
bottlemanpt's Avatar
Too much oil?
I just took my eco boost 150 to the dealer to get my second oil change. They put in seven quarts of oil when my manual says six, they put in six last time. When I asked the service manager he said you have to add one quart for the filter. I think he is trying to make it look like they did nothing wrong. after I got home, about fifty miles, I checked the oil, it was an inch and a half over the full hole on the dipstick. They may have put more than one quart too much oil in it, I intend on taking it back to have them suck the extra oil out. Do you think it hurt my engine driving with all that oil in it?
Thanks.
Old Apr 6, 2014 | 08:38 PM
jgger's Avatar
As long as the crank shaft isn't whipping the oil into a froth, it shouldn't hurt it.
If the crank shaft is turning the oil to foam it's the same as not having enough oil pressure. The oil pump can't pump foam or air so you loose oil pressure.
The six qts should include the amount needed to fill the filter, the service manager is an idiot, IMHO.
Old Apr 6, 2014 | 09:03 PM
08FX4SC's Avatar
I'd drain it out now. Just drain a little out of the pan until your dipstick is down to full. Most dealers are really stupid about the vehicles they sell. I just fill the filter before I spin it on. It certainly doesn't take an extra quart.
Old Apr 6, 2014 | 11:09 PM
Casey05's Avatar
Too much oil can cause many problems and end up in a blown motor. Keep good documentation and take it back to be fixed. Don't do it yourself or you run the risk of the dealership denying any claim arising from this. Maybe even call ford motor comapny to lodge a complaint. Especially if the issue doesnt get immediately resolved. Whatever you do, don't wait to fix the problem.
Good catch.
Old Apr 7, 2014 | 10:01 AM
stormtech's Avatar
I rarely have anyone else change my oil. But if I do, I always check the dipstick at the garage before I start it. I also verify the correct oil was used when picking it up.
When I was driving big truck, it happened a couple times. The old oil was never drained and 10 gallons were added.......
Old Apr 7, 2014 | 12:16 PM
mkosu04's Avatar
they were probably confused by which engine you have... the old 5.4L V8s took 7 quarts.
make them fix it, document what happened, and then NEVER GO BACK!
Old Apr 9, 2014 | 03:26 PM
FordService's Avatar
Ford Customer Service Team
Originally Posted by bottlemanpt
I just took my eco boost 150 to the dealer to get my second oil change. They put in seven quarts of oil when my manual says six, they put in six last time. ...
bottlemanpt,
I'm happy to document this dealer feedback for you so it can be reviewed by the customer relationship manager at the dealership. Please PM me your name, phone number, VIN, mileage, and dealer info, and I'll do so.
Ashley
Old Apr 12, 2014 | 12:00 AM
To Ashley
Yes, I would like your help. Can I send you the information so only you can see it? I am not too keen on how this site works, and the information is personal. Please tell me how to go about it. Thank You, Ashley.
Old Apr 12, 2014 | 09:37 AM
Click on her username in one of her posts (FordService, upper left) then choose send private message. That's what "PM" stands for - private message.
Old Apr 12, 2014 | 11:01 AM
Sbradenadams's Avatar
8q on the new 5.0 V8 coyotes
Old Apr 14, 2014 | 10:23 AM
Hi bottlemanpt,
Like glc said, if you click on my name, it'll let you send a PM. It is pretty much like an e-mail sent through the forum.
Ashley
Old Sep 21, 2014 | 02:48 PM
Smile Can't reach Ashley
Ashley, I can't seem to get a hold of you. I would like to P.M. you.
Thanks,
bottlemanpt
Originally Posted by FordService
Hi bottlemanpt,
Ashley
Old Sep 22, 2014 | 11:25 AM
Thanks,
bottlemanpt
Hey bottlemanpt,
I'll shoot you a PM that you can respond to. You'll be able to find it under your private messages in the top-right corner of the page.
Nick
Old Sep 22, 2014 | 07:49 PM
Fastbob's Avatar
1 qt. overfull won't cause any problems, but sounds like you have more than an extra qt. Drain some out. I drove mine oil change to oil change (approx. 8,000 miles) with an extra quart in it and had zero issues. I am still not sure why I decided it needed 7 qts.
