alright guys im stumped!
My 2011 Fx4 5.0 3.73 E-locker 57k auto spring 2 1/2 lift level 1 1/2 in back 295/60/20 Terra grapplers. Alright while I'm driving when your lightly on the gas pedal I can hear a whistle/ howl it is only when in gear. Noise goes away as soon as I slip it in to neutral and coast with my foot on the gas slightly. Put it back to drive comes right back instantly . When I just let off the pedal and let it coast in gear the noise goes away so it is only when theres a load on it. Can't hear it with windows open. Does not sound like the typical U Joint squeak. Don't think its a pulley on the motor because it doesn't do it in neutral or really change its volume with more Rpms / speed. Any ideas.?
Does it sound like a fake turbo whistle?
I've had that whistling sound since I bought my truck. It's in the air box somewhere. It's sucking air. I read somewhere that there is a fix for it. But it's never bothered me enough.
Mine does it when I'm just barely pressing the gas pedal when in drive. I can flutter the pedal a little and make it happen.
my 2013 eboost 3.73 4x4 was doing the same thing. rear pinion carrier bearings were shot. replaced 2x now under warranty the truck now has 32K on it.
rear pinion bearings.
I actually brought it up a couple times during oil changes and they 'could not replicate the issue' so I kept driving until the radio would almost not go loud enough to cover up the noise.. can you hear it now!! haha
