2009 5.4L fuel rails
Old Apr 2, 2014 | 10:43 AM
bheeres's Avatar
For my truck build it would be best if I was able to switch to a new billet fuel rail so I could feed each rail individually. Problem is there seems to be a lack of engine parts for the 5.4L 3v, companies like Aeromotive don't offer a rail for this truck. Anyone out there know of a company that makes rails?
thanks
Old Apr 2, 2014 | 04:16 PM
Ross-FX4's Avatar
Must be a monster build if the OEM 11/16 ID rails ain't up to it.
You can fit Metco GT 3v rails if you modify the mounting tabs.
Old Apr 2, 2014 | 07:20 PM
bheeres's Avatar
Well, really just prepping for the future so I only need to do the fuel system once. In my last truck I ran a Supercharged 347 and had great luck feeding the rails with there own fuel line versus feeding into on rail and returning out the other. That's my goal. Maybe I'll have to see it that is a possibility with the factory rails.
Old Apr 2, 2014 | 07:22 PM
bheeres's Avatar
This truck will be Heads, Cams, D-1SC Procharger.
Old Apr 2, 2014 | 07:25 PM
You don't have a return system, the 09 uses a FPDM to vary the fuel pump pressure.
Old Apr 2, 2014 | 07:29 PM
bheeres's Avatar
The fuel system on the truck is completely gutted and am running a fuel cell, this is a total Aeromotive system. So mine WILL have a return system
Old Apr 2, 2014 | 11:31 PM
Ross-FX4's Avatar
Ah your gonna need aftermarket rails if your running return. You could always TIG another feed line onto the stockers.
Like I said, Metco's, they have a FRPS boss so your gonna need a blank.
Metco's are the only ones ive seen with seperate mounting tabs. Others like fore have the tabs machined off the rail.
