Will mirrors fit ?
Old Mar 18, 2014 | 08:34 PM
Bigmoss's Avatar
Will mirrors fit ?
I know the body styles changed but does anyone know if mirrors from a 2012 fit a 2008 in the pic the bolts looks in the same place just not sure of the style diff ?
Old Mar 19, 2014 | 12:42 PM
Bigmoss's Avatar
No one ?
Old Mar 19, 2014 | 12:46 PM
05RedFX4's Avatar
Short answer yes. There used to be a swap chart on the wiring differences from the various years with pinout diagrams on tasca parts. Should still be there.
Here it is
http://tascaparts.com/pages/index.cf...8&pageid=10207
Old Mar 19, 2014 | 12:54 PM
Bigmoss's Avatar
Thanks for the diagram that will come in handy, I like the new lights with the signal on the back etc so I might give them a try, here is a pic
Old Mar 19, 2014 | 01:28 PM
05RedFX4's Avatar
Unless ford changed things again, everything from 2007 up should have the same pinouts. those mirrors should be plug n play on your truck.
Old Mar 19, 2014 | 01:32 PM
They'll fit any truck 04 and up, but suppose the wiring connectors could be different if 05red is right. Even if it is, it's only a matter of messing around with it to make them work.
Old Mar 19, 2014 | 01:51 PM
05RedFX4's Avatar
If you look at the chart on tasca, the pinouts changed in 07. Don't know if they changed again or not. If the mirror your using doesn't match up just change the pinouts to what you need.
