aDJUSTING HEADLIGHTS
Old Jan 25, 2014 | 06:57 PM
34ford's Avatar
Question aDJUSTING HEADLIGHTS
I have a 2013 w/ standard halogen headlights. I have researched several sources and find conflicting info on which direction ( clockwise or counter clockwise ) to turn headlight adjusting screws to adjust the lights UP. Any feedback would be wonderful. Thanks in advance, 34.
Old Jan 25, 2014 | 07:09 PM
thelariat02's Avatar
Why don't you just turn the screw and see what way it goes.. If it guess the wrong way then turn the other way... Why do you wanna move your headlights up.
Old Jan 25, 2014 | 07:10 PM
MGDfan's Avatar
Hi And Welcome!
What's the Owner's Manual say?
I'd look it up meeseff but I'm in da bayg.
MGD
Old Jan 25, 2014 | 07:14 PM
I don't have a 09+ f150 , but if the adjustment screw is on top of the headlight then common sense would say counter clockwise.
Old Jan 25, 2014 | 07:33 PM
34ford's Avatar
The manual tells WERE the adjuster is but not which way TO turn it. Thanks, 34
Old Jan 25, 2014 | 08:00 PM
http://www.f150forum.com/f38/headlig...stment-111465/
Recheck your manual. Looks like in 2010 they had a misprint and it said to turn it counterclockwise to drop lights but its actually to raise headlights. Sorry for the confusion.
But then again this could have been found out by doing it yourself.
Old Jan 25, 2014 | 08:47 PM
Just turn it one way and see what happens . . . that's WAY faster than looking it up
Old Jan 26, 2014 | 05:40 AM
34ford's Avatar
2013 manual is different. Thanks, 34
Old Jan 26, 2014 | 09:33 AM
MGDfan's Avatar
Sure.
But - the Headlights are not. Same heads from 09-14 (non HID of course).
MGD
Old Jan 26, 2014 | 01:49 PM
34ford's Avatar
After research ccw is up- clockwise down , info last printed in '10 or '11 manual. Not in 2013. 34
Old Jan 26, 2014 | 02:36 PM
canadianelbow's Avatar
34, several have said the same thing, and they say it, because it is the simplest. I've been a bodyman for years and years, and have never looked up which way to turn the screw. Just park your truck 15 feet away from a wall, or garage door, and turn the screw. Observe what happens on the wall. If it is not the way you wanted it to go, then it's a super easy decision on what to do next. With the typing and research you have done here, you could have had it done before even logging in here.
That said, welcome to F150online. The folks around here are always more than happy to help, you just took some of the blunt advice a little harshly.
Old Jan 26, 2014 | 04:07 PM
After research ccw is up- clockwise down , 34
Isn't that what I said?
Is there an echo in here?
Old Jan 26, 2014 | 05:01 PM
34ford's Avatar
I guess my problem is I am 2x the age of most people on this site. I build hot rods ('28-34) Fords for a hobby and I am used to hanging out on H.A.M.B. and some of the real do it yourself hot-rod sites. The response attitude is very different , but no complaints just thanks for feedback. 34
Old Jan 26, 2014 | 05:17 PM
Then you should be used to doing things by trial and error. None of us are trying to be rude, it just isn't worth your time doing all of this research and question asking for something so inherently simple. I just adjusted one of my 06's headlights on Friday and asking which way to turn it never entered my mind, I just turned it and oberved what happened.
Old Jan 26, 2014 | 06:34 PM
34ford's Avatar
Actually you have it just backwards, we research all possibilities BEFORE we do anything as some of the parts/ items we work with are over 70 yrs. old and you cannot find/ or afford to replace many of these. When you are assembling suspension parts you gather all input on kingpin angles, ackerman effect , caster/camber etc. you can find so you get it right the 1 st time. It is too expensive in time and money to trial and error. Thanks for your input, 34
