2013 oem hid lights
2013 oem hid lights
Hey has anyone else had issues with the new hid lighting.
I bought the truck new last year and had issues with the shutters not dimming from hi beam to low beam. I live in Canada and don't have a heated garage to thaw the truck if this is a freezing issue, the headlights have been replaced once since I first had the issue. Is this a common issue or am I just having bad luck sometimes both lights stay "open" or non focused but mostly the left hand side anyone have suggestions?
Vehicle is a 2013 fx4 appearance pkg
Hi.
Sticking cutoff shields (not shutters, lol): Been reported at least once, recently: https://www.f150online.com/forums/il...?highlight=hid
Use the warranty you paid for - be civil but firmly insistent - this is NOT normal. Escalate as necessary - it's also a safety concern ( blinding other folks ).
Good luck.
MGD
Good luck.
MGD
I could be wrong though.
Most high beams in a bi-xenon projector the cut-off shield is held in place by a spring and when you turn on your highs 12v activates a solenoid which pulls down the shield.
+1, Use the warranty
2nd replacement set of hid's the whole assembly is being replaced next week. they do work fine in cold weather if I don't use brights, any technicians have troubleshooting ideas I can pass on to the dealership if the new assemblies have the same issues? The dealership has had to contact the warranty hotline for both repairs first time I replaced them it was already spring before parts arrived so I'm not sure this is the fix
Sounds line the same problem that my mini H1s have. Does it start working after having the lights on for awhile?
Sounds to me like they need a stronger return spring for the cut off shield.
Sucks to hear the problem usually OEM projectors never have problem..
I know one good fix. Upgrade the projector to an evox-r projector and never have problems again
It's hit or miss if they will dim after keeping them on for an extended amount of time, last night I was followed by a similar f 150 to me and his lights were just dancing not focused at all it was -50 with the windchill the lights worked properly once then of course I get into the city and they are stuck on hi.... Errrr the stealership says they only replace the entire assembly...
