Turn signal gone crazy
Old Aug 10, 2013 | 11:26 AM
brazzeal15's Avatar
For some reason my left turn signal blinks fast, as if there is a bulb out, but there are no bulbs out? Could it be the fuse?
Old Aug 10, 2013 | 12:46 PM
05RedFX4's Avatar
There is a bulb out somewhere, or a break in the wiring. The turn signal is designed to blink faster when a bulb is out to signal that you need to check your bulbs.
Old Aug 10, 2013 | 03:40 PM
Dog'em's Avatar
Does the turn signal light up and work properly ? I am with Red, bad electrical connection somewhere in the circuit. If not bulb or wiring could be a bad relay.
Old Aug 11, 2013 | 09:46 AM
05RedFX4's Avatar
Another thing is there could be a short on the left side somewhere. A flasher is basically a self resetting breaker, and when the turn signals are on the load provided by the bulbs is enough current to trip the breaker causing the flasher to operate. When a bulb burns out, the resistance decreases thus increasing load (basic ohms law) and the flasher operates faster. So when a flasher goes into overdrive, you have an increase in load on that side of the circuit. typically its a burnt out bulb, but if all your bulbs are working then you have a short to ground somewhere on the left side.
Old Aug 11, 2013 | 12:38 PM
brazzeal15's Avatar
Wow..... I don't even know where to start looking for a break or short... I'm electrically impaired.
But I did just go and check, all lights on the truck function properly. No burn outs.
Old Aug 11, 2013 | 03:29 PM
Dog'em's Avatar
Any reputable shop should be able to pull the bulb and put an ohm meter on it to check the circuit at minimal expense.
Old Aug 12, 2013 | 12:35 PM
razorsharp1's Avatar
You did not happen to put in an LED lamp did you?? Some of them don't have the resistor needed to prevent the "fast blink" as the resistance is not high enough.
Most are OK now but there are still a few out there that need the resistor.
BJ
Old Aug 14, 2013 | 03:57 PM
brazzeal15's Avatar
BJ
Nope, still all OE parts.
Old Aug 23, 2013 | 09:41 PM
OnBelay's Avatar
No.
But it could be the flasher itself. Read the manual, figure out where the flasher is, and spend the $4 for a new one.
