Leveling kit
Leveling kit
what size of leveling kit do i need to putt on been told 3, 2.5 2 and 1 in the front dont really want to lift back just make front sit higher and still look good
1.5" if you're not doing anything to the back. With 2" front spacers and a stock back your truck will look higher in the front than in the back. Not cool IMO.
I have a 2010 as well. FX4. Is yours a 4x4? I went with the 1.5" AutoSpring for the front. Nothing added to the rear. Here's the thing. The 1.5" AS level is supposed to give you 2" of lift. Or at least it used to. Its the same spacer they used to lift the 2004-2008 models 1.5", but the geometry differences on ours actually gives it 2". Its also the same dimension spacer as the other companies 2" kit spacers. (the size of the spacer is not the amount of lift you get) Does that make sense? Also, you can look at my pictures to see if thats the look you're going for. I'm still torn as to whether I should have gone with the 2" AS or not. Its almost level, but I think it still has some rake to it.
But I now have the same tire/size and lift on a 2013 and no trimming was needed.
