platinum tailgate
FORD:
2009-2010 F-150
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
NOTE: READ AND UNDERSTAND ALL INSTRUCTIONS BEFORE PERFORMING PROCEDURE.
NOTE: OBTAIN ALL REQUIRED MATERIALS AND TOOLS BEFORE PERFORMING PROCEDURE. FAILURE TO USE SPECIFIED MATERIALS AND/OR DEVIATING FROM THE FOLLOWING SERVICE PROCEDURE MAY RESULT IN AN UNSUCCESSFUL REPAIR.
If equipped, remove the rear video camera.
Apply masking tape over the tailgate badges and on the tailgate surfaces surrounding the applique.
Spray a liberal amount of 3M Prep Solvent-70 along the top of the applique and in the separated area between the applique and tailgate. Allow saturation time for the solvent to breakdown the adhesive tape.
Separate the top of the applique from the tailgate using a removal tool such as 3M Side Molding and Emblem Removal Tool or equivalent. (Figure 1)
NOTE: APPLIQUE IS EQUIPPED WITH FOUR (4) ATTACHING CLIPS LOCATED HORIZONTALLY ACROSS THE MIDDLE OF THE PART. VEHICLES BUILT AFTER 12/20/2009 MAY HAVE TWO (2) ADDITIONAL CLIPS, STAGGERED EQUAL DISTANCE ALONG THE TOP EDGE. USE CARE NOT TO DAMAGE THE CLIPS AND CLIP MOUNTING TABS DURING PART REMOVAL.
NOTE: DO NOT USE EXCESSIVE FORCE WHEN REMOVING APPLIQUE AS DAMAGE TO THE PART AND/OR TAILGATE PAINT MAY OCCUR.
Continue to carefully work the top section of the applique free using the molding removal tool only as required. Apply additional 3M Prep Solvent-70 and allow time for the solvent to work.
Once top section of applique is free, remove the tailgate and place on a suitable workstand so the bottom section is raised and accessible. Replicate steps 4 and 5 on the bottom section of the applique.
Remove applique and place on a suitable workstand equipped with padding that will protect the finish side of the part from damage.
Remove all existing adhesive tape from the applique and tailgate using 3M Stripe Off Wheel. Operate the wheel at slower RPM for best results. If necessary, have an assistant hold the part.
NOTE: SOLVENT WILL BE ABSORBED IN THE ORIGINAL TAPE AND WILL DRIP ON THE REPLACEMENT TAPE CAUSING A BONDING FAILURE. THEREFORE IT IS CRITICAL TO REMOVE ALL ORIGINAL TAPE.
Soak the residual adhesive on the ribbed sections along the top and bottom of the applique with 3M General Purpose Adhesive Cleaner 08984. Remove all adhesive from the ribs with a wire detail brush and blow with compressed air. (Figure 2)
Thoroughly wash the tailgate and applique to remove all solvent residue. Blow dry and repeat as required.
NOTE: FAILURE TO COMPLETELY REMOVE SOLVENT RESIDUE WILL PREVENT REPLACEMENT TAPE FROM ADHERING CORRECTLY.
Apply a 5" to 6" wide layer of masking tape along the entire length of the top and bottom sections on the finish side of the applique. (Figure 3)
Tape will be applied to the outside perimeter of the applique in a picture frame pattern. Wipe the flat vertical sides and ribbed horizontal sections along the top and bottom of the applique with Isopropyl (rubbing) Alcohol. Repeat on the corresponding locations of the tailgate.
Place the tailgate flat on a suitable workstand with the outside surface exposed. Allow plenty of space in the work area.
Apply 3M Tape over the top and bottom ribbed sections as shown. (Figure 4)
NOTE: DO NOT APPLY ONE CONTINUOUS LENGTH OF TAPE ACROSS THE BOTTOM. A SIZABLE DISTANCE BETWEEN THE TWO SECTIONS OF TAPE MUST BE PRESENT FOR DRAINAGE.
NOTE: DO NOT ALLOW THE TAPE TO EXTEND PAST THE RIBBED SECTIONS.
Apply tape to the vertical outside edges as shown. Do not allow tape to extend to the ribbed sections or near the raised profile in the middle of the part. The individual sections of tape in this area should be no longer than 4-3/8" (111mm). (Figure 4)
Use a hand roller to firmly wet-out the tape.
Apply 1/2" wide by 3" long bead of 3Mâ„¢ Duramix Universal Adhesive 08214, approximately 1/2" below the center of the upper sections of tape. Do not allow the adhesive to make contact with the tape. (Figure 4)
NOTE: THE ADHESIVE HAS 10 MINUTES OF WORKTIME.
Remove tape backing, and with the aid of an assistant immediately place the applique on the tailgate and seat the attaching clips.
NOTE: DO NOT REMOVE TAPE BACKING UNTIL THE APPLIQUE IS READY TO BE INSTALLED.
Use a hand roller to firmly wet-out the tape around the perimeter of the applique.
Place a 2"x4"x84" common stud along the top edge of the applique. Secure the lumber on each side of the tailgate using locking C-clamp pliers with swivel pads. When clamped properly the lumber will form to the contour of the applique. (Figures 5 and 6)
Place a second stud along the bottom section of the applique, attaching in the same fashion.
Allow the applique to remain clamped for a minimum of 4 hours.
Reinstall the tailgate.
If equipped, reinstall the rear video camera.
2009-2010 F-150
ACTION:
SERVICE PROCEDURE
