2009 F-150 Starts then immediately dies
Old Mar 18, 2013 | 10:10 PM
jamiep's Avatar
Update: Got a new code reader and it pulls code P025A - Fuel Pump Module Control Circuit/Open
Does this sound like a FDCM? Ideas?
Old Mar 19, 2013 | 11:44 AM
canadianelbow's Avatar
Originally Posted by jamiep
No, this battery is the original one, and has never been disconnected. MAF is indeed connected. It should throw a code if the MAF is an issue, right? I can't get the motor to stay running for more than about 5 seconds before it panics and quits on me....
Check out this post....... I'm thinking that a new battery, as dumb as it sounds, might just solve your problem.
http://www.f150forum.com/f38/intermi...10-4x4-187253/
Outside of that, another option is to drop $11 on a short term subscription to a pc/ed manual from ford, and it should give you a flow chart for your code. I have a hard copy of the ford service manuals including the wiring diagrams, but it tells me to refer to the PC/ED manual.
http://www.motorcraftservice.com/vdi...il&kevin=rules
A quick search on google found this too, but I still would try a new battery first. I've read countless reports of how a new battery solved so many problems. .........
P025A:
Description: The powertrain control module (PCM) monitors the fuel pump command (FPC) circuit for a concern. When the PCM commands the fuel pump (FP) ON, the PCM is able to detect a short to voltage on the FPC circuit. When the PCM commands the FP OFF, the PCM is able to detect an open circuit or a short to ground on the FPC circuit. The test fails if the voltage is less than orgreater than a calibrated limit, for a calibrated amount of time.
Possible Causes: FPC circuit open or short to ground
FPC circuit short to voltage
Damaged fuel pump control module
Diagnostic Aids: Check for any harness concerns.
GO to Pinpoint Test KC
Actual info source, http://www.n8fan.net/fopen/a2V5d29yZ...lwdGlvbnMucGRm
Old Aug 9, 2021 | 11:59 AM
Dasptx's Avatar
Wondering what the issue was with this, having the same issue with my 2009 F150 4.6 with 209k miles
Old Aug 9, 2021 | 02:08 PM
Exact same issue with the exact same code?
Old Aug 9, 2021 | 02:11 PM
Dasptx's Avatar
Same issue but no codes. Check engine light is off, checked for codes and no codes. Truck was working fine, parked it for a week and now having this issue
Old Aug 9, 2021 | 03:11 PM
I'd first suspect the FPDM or the MAF. Neighbor's Crown Vic was doing the same thing and it was the MAF. Disconnect it, if it's a bad MAF it will keep running.
Old Aug 9, 2021 | 03:58 PM
Dasptx's Avatar
I've already looked for the FPDM above the spare tire, it's not there. From what I've read only 04-08 models have an FPDM. I turned the truck on and unplugged the MAF sensor and the truck still turned off. Only stayed on for about 5 seconds
Old Aug 9, 2021 | 05:26 PM
Post #179:
https://www.f150forum.com/f4/fuel-pu...8/#post4051791
Old Aug 10, 2021 | 09:42 PM
Dasptx's Avatar
Replaced the FPDM and that fixed the problem. For whatever reason when I called AutoZone they had a hard time finding the part and finally found it but didn't have it. O'Reilly's had it, they also had a hard time finding it. It was $67, Dorman 601-225 is the brand and part #. Thank you so much for your help.
