Biltein 5100 and Camber Kit
Old Feb 26, 2013 | 11:22 AM
  #31
MHP1's Avatar
Originally Posted by kingfish51
That is possible, but the big change will be the camber since the inside of the lower A arm is fixed and the fulcrum. Pushing it down causes it to swing inward. Further you push, the farther inward.
That is correct, the kit they put in allows you to adjust the lower control arm outward to correct the camber. I am being told it can be done without the kit but it is more difficult. I probably didn't need it since it was such a small lift but oh well its done and if i decide to raise it further in the future it will be there to help in aligning.
Happy with the outcome
