How does it work?
Old Oct 4, 2012 | 10:40 AM
JasonInSeattle's Avatar
How does it work?
I'm not a gearhead at all, but I like to know how stuff works. There are a few good articles online for how automatic 4WD works, although it's a little difficult to figure out which specific implementation is used in the new 2013s.
So, two questions:
* Is there a good reference for how 4WD auto works in the 2013s? I want to understand what physically (or electronically) happens when you flip the **** from 4WD auto to 4WD high, etc.
* Is there a good technical reference for all the systems in the 2013s? I get the urge to research a different part every couple of days (the last time it was "how does a limited slip differential work"... noobish, I know), and having some starting point, even if it's a little over my head, could make the process a lot quicker.
Thanks!
Old Oct 4, 2012 | 10:53 AM
Look at it this way - vehicles with Auto 4wd have a transfer case that works like a differential. In Auto, it's like a limited slip and in "regular" 4wd it's locked.
Old Oct 4, 2012 | 10:58 AM
That's what I figured, but there was some ehow article about a sensor on the front axle to detect rotational differences from the back. That seemed... complex, so I thought maybe I could find out why it would be necessary (if it even applied).
Old Oct 4, 2012 | 11:46 AM
It's necessary to determine how much torque to apply to which end. It's like an electronically controlled limited slip.
