2012 fx4 leveling kit which one
You can run into that problem, even with the offset spacers like Autospring's design. The issue is there has been differences in the length of the shocks. I've got an Autospring 2" and would recommend it. I actually think my UCA hits the spring at full droop as well but not worried since it probably won't see full droop.
Im no hardcore off roader but I do venture off into the swamps around here now and then. After these tires are shot im planing on a set of nitto trail grapplers. So Im guessing I may go with Autospring. I did look on ebay but it seems most leveling kits i have found are 2 1/2 lift in the front. I dont want to completely destroy the angles of the front cv's and i think 3 is the max with faster wear I may be wrong.
I would go 2". 2.5" will put them at a pretty good angle. If you're running the factory 20s you can fit the 34" Nitto Trail Grapplers with the 2" AS kit.
2" Procomp leveling kit, 3" rear blocks. will fit 35 X 12.50 on off set rims with minor trimming to the plastic on bottom of the bumper.
Just traded it in on this 2012 FX4 EcoBoost, soon too have a 2 1/2" leveling kit with these rims and tires on it.
