take off stop clunk
Old Sep 8, 2012 | 02:06 AM
tbones's Avatar
take off stop clunk
Is it possible that the springs slap and make a clunk noise on take off and or slowing down. On the lower spring there is like a 1" gap with a plastic bushing on top of lower spring. On take off the axle will slap up or twist and lower spring against the other springs casuing noise?
Old Sep 8, 2012 | 12:43 PM
High-ster's Avatar
There is a TSB on that clunk.
Something about the slip yoke and driveshaft splines that need special grease.
My '10 XLT 4.6, 4x4 doesn't have it. 1 pc driveshaft.
Old Sep 8, 2012 | 01:00 PM
If it is the bump just before you come to a complete stop and just when you get rolling, then it is probably the slip yoke on the end of the drive shaft. As mentioned, ther is a TSB for warranty service if you are still in warranty. My dealer did mine and it is smooth now. I have no idea what it cost if you are out of warranty. The slip yoke bump is not a big concern, just annoying. They should lube them properly at assembly.
Old Sep 8, 2012 | 09:58 PM
Sullyman's Avatar
Mine had never done that, so they must lube them properly at the assembly plants now.
Old Sep 8, 2012 | 10:53 PM
coobies5's Avatar
It's something with the driveline, our 2010 with the 2 pc driveshaft did it and we took it in and they put some teflon coating to fix it
Old Sep 8, 2012 | 11:50 PM
Teflon grease is what they use on the slip yoke.
Old Sep 9, 2012 | 12:56 AM
bansheerider's Avatar
I've had this TSB done and the issue is coming back.
