2011 F150 Abs Speed Sensor
Old Aug 10, 2012 | 06:56 AM
Invalid_access's Avatar
I need to replace the harness on the abs sensor on 2011 f150. A cat got up on the rear axle and broke the wire and plug. I soldered the wires back together and taped it all up. On the plug the plastic tab is gone. It holds on the axle, but I'd rather have a new one with the tab. I hope the harness comes with everything. Thanks for your time. On yea it is a 2011 fx4 ecoboost f150.
Old Aug 10, 2012 | 09:38 AM
I am thinking this is what I need to fix the connector. It has two wires. I just wish I could see the end of the connector. Any ideas? http://http://www.amazon.com/Motorcr.../dp/B000C5BYR6
Old Aug 14, 2012 | 01:26 AM
GoRacer's Avatar
I've replaced both on my '04 trying to resolve my ABS issue (new hub also) and still have the old ones in the garage. I was going to put those back on and sell the new ones but never did.
They should come in a box with grease and a screw. It will have connectors on both ends. I got mine disounted from sunrise which used to be oe ford.
It's a little bit of work if I remember correctly the brake rotor has to come off. I couldn't tell you if there is any difference with the new turbo 4 eco.
