6R80 Transmission Normal Termperature?
Old Jun 8, 2012 | 01:09 PM
Nimrod's Avatar
6R80 Transmission Normal Temperature?
What is considered a "normal" operating temperature (fully warmed up and running) for the 6R80 tranny in the 2009-2012 trucks, under no-load - to - light-load conditions? I am seeing temps that max out in the 190*-195* range on the LCD "gauge mode" display, and the pointer is almost exactly in the center of the instrument cluster's tranny temp gauge.
Old Jun 8, 2012 | 08:33 PM
roadrunner5's Avatar
I have a 2011 Screw Lariat with 6.2 Engine and I have not towed a lot yet, but running around locally my temps on a 100 degree are in range of what you are seeing. Yeah my gauge is centered too, but I think that is considered normal . I am anxious to hook up my 10,000 lb loaded Toy Hauler and head for the hills and see where transmission temps go.
Old Jun 8, 2012 | 09:56 PM
Dmckinney33's Avatar
I have a 2012 screw EB and it runs around 196. I towed 9000lbs and my temp never went over 201 and I pulled some mean hills at 65-70 no problem!
Old Jun 9, 2012 | 12:59 PM
1depd's Avatar
Most of Ford's guages are nothing more than idiot lights. They show three settings, off/low, on/normal, or too high.
Old Jun 9, 2012 | 03:22 PM
Kevin O.'s Avatar
That is exactly where mine runs at and when towing my camper it runs 197-204 degrees depending on the hills..
Old Jun 9, 2012 | 04:06 PM
Nimrod's Avatar
Thanks for the confirmations that what I am seeing is about "normal." I'm not used to thinking that such elevated transmission temps are considered OK...but I suppose that the special sauce, with it's 11 secret herbs and spices, that Ford is using these days in the F-150 tranny is made to withstand the rather high temps without breaking down.
Old Jun 9, 2012 | 04:09 PM
MGDfan's Avatar
Discussed befer: https://www.f150online.com/forums/20...ight=6r80+temp
Search does come in handy ...
Old Jun 9, 2012 | 07:07 PM
Nimrod's Avatar
Yeah, I know that...for the record, I *did* try some searches, but I wasn't successful in bringing up that thread - thanks for highlightning it for me
Old Jun 10, 2012 | 01:04 PM
goducks's Avatar
x2.
