tires + wheels
Old May 27, 2012 | 07:57 PM
Fishhunt17's Avatar
tires + wheels
Hey guys, i have a 2011 f150, with the 2.5" rough country level, i want to put moto metal mo961 wheels (9") on 35x12.50x18 tires, im just curious if anyone knows if ill be okay for cleanace, because i heard that the levels only give you clearance for 35s on stock offset ect.. i believe the offset is 18
Old May 27, 2012 | 09:23 PM
wandell's Avatar
You can fit 35x12.50's easily using the stock wheels or an 8 inch wide wheel with 5.5 inches of backspacing. Going outside of that and you risk having serious rubbing or needing to do some trimming. Personally, I'd go with the wheel you've chosen and a slightly smaller tire.
