USB broadband
USB broadband
So I've been reading, if I'm right... I buy a USB broadband modem, and I have wifi no matter where I'm at... It doesn't work on 3G or anything, correct? And if so, does anybody recommend a particular one?... Thanks for any help
It is relevant to Fords, since you can use it with Sync.
My understanding is this:
1) You buy a USB broadband modem that will use 3G cellular service
2) You pay the fee for the modem (around $60/month I think) through AT&T, Verizon, etc.
3) Plug into the USB Sync port
4) You have a WiFi hot spot in your truck that can be used by multiple devices.
Pretty slick. I did not know that.
Though it's probably cheaper overall to pay for tethering on a smartphone, if you have one that is capable.
But, I thought the cost of adding tethering to your phone package was about the same as the cost for broadband modem access.
Of course, I don't have a truck that supports it, nor do I have a modem, nor do I plan on having one any time soon.
you could go with a dongle however you might also already have data plan on your cell.
any smartphone will support tethering. its about an extra 20 dollars a month depending on your carrier. if you have verizon or sprint your internet will drop every time you receive a call(att you can multitask). If you buy a mobile hot spot its like 50 dollars a month and you get 5GB of data(again depending on your carrier)
you can jailbreak your phone and get it for free, or you can pay for it each month and your carrier will enable that feature on your phone.
you have to buy a mobile hotspot(the usb only works on one device). It will work anywhere your mobile provider gets data services. you said you have verizon so check this out. Verizonwireless.com/coverage
