First time towing with 2010 FX4....few rookie questions
Just found this on the U-Haul site, so I think you need a trailer to be safe:
Front-wheel or all-wheel drive vehicles must not weigh in excess of 3,450 lbs.
Rear-wheel or four-wheel drive vehicles must not weigh in excess of 3,900 lbs and you must disconnect your driveshaft.
Another thought...doesn't the military cover the moving expenses? Why not have them move it with your stuff?
Even thought the dolly only supports the front half, the tongue still has to take the full weight of the dollied vehicle. Are you sure that 3450 lbs isn't taking that into account? Are you sure the 3450 isn't the TOTAL vehicle weight? I would think it is.
You haven't mentioned if your Escape is AWD or FWD, but that will make a difference as you may need to disconnect a drive shaft if it is AWD.
Ok so I called Uhaul and they had no idea if the max weight for the dolly is for the whole vehicle or the front GVWR. I talked them into upgrading my trailer to the car hauler for an extra $100 vs $250. I feel a bit better now, thanks for the advice guys
Sounds like it's going to work out well for you! Safe travels to you and your family!
I wouldn't worry about using cruise on the flats. I tow a 7200lbs TT that will have way more frontal impact than your Escape. I use cruise all the time on the freeway and long stretches of straight highway. I have a Scangage hooked up and see no higher tranny temps using the cruise. Only time my tranny temps go up is when I'm in the mtns climbing 4-6% grades, where I don't use the cruise. I let the tranny do it's thing and have no probs. FWIW 2010 F150 5.4 3.73, maxtow 145" WB. Screw. Just remember your trucks reciever is only rated for 500/5000lbs w/o weight distribution. So your smart to get it weighed before you leave.
Hmmmmmmmmm......
While towing, if I DON'T use the T/H mode, the transmission will downshift easily for small hills.
If I use the T/H mode, my tranny doesn't hunt for gears but stays mostly in 6th gear unless traveling up a grade..............
And I use the cc all the time while in the T/H mode. No excessive gear changing.
4.6,3-V 4x4 Scab. Tow pkg w/3.73 L/S diff
Your 7200 GVWR is the total weight of just the truck - it includes everything loaded in the truck and bed, and the tongue weight of the trailer. Once you get everything hooked up and loaded, fill the gas tank and go hit a CAT scale - the weight slip will have the front axle weight, rear axle weight, and trailer axle weight. Add up the front and rear axle weights and that should not exceed 7200#. It probably will if you have a lot of crap in the truck, but if it's only a couple hundred pounds don't sweat it.
Note that U-Haul does not recommend that you exceed 55 mph while towing their car hauler.
There are several ratings, none of which you should exceed. Like I said, go run the rig over a CAT scale.
1. Front and rear truck axle weight added together should not exceed GVWR, which is 7200# in your case.
2. Front axle weight should not exceed front GAWR, rear axle weight should not exceed rear GAWR, both these ratings are found on the door sticker.
3. The total weight - front axle, rear axle, trailer axle added together - should not exceed your GCWR.
You will always wind up exceeding GVWR long before you hit the 9600# towing limit. That number is usually calculated with a completely empty truck - only a 150# driver and 1/4 tank of gas - and minimum safe tongue weight. How far over GVWR you go is your decision. The more crap you load in your truck, the sooner you will hit the limit. You could even hit 7200# before you even hook up a trailer!
Yes, if you plan on towing a 8000+ # toyhauler you will need a WD hitch, brakes, and probably some air bags in the rear suspension. You would also need to load your crap in the toyhauler, not the back seat and bed.
