09 Blend door actuator replacement
So driving to work today turn on ac and only drivers side is cold, pass side hot air no matter what temp setting is. Searched threads and everything leads to the blend door motor. My question has anyone replaced it themselves and is it a pita to do?
Mine had to be changed out as a warranty item right after purchase. Shop did the work. Looked like a real pita. Both front seats and center console had to be removed. Dash had to be taken back (or removed?) to get to it. These were just the items I saw on my shop visits.
Hope this helps you make a decision!
