Oil Change Message, Only 1200 Miles
Old Jan 31, 2012 | 01:04 PM
House Doc's Avatar
I think the algorithm used by my 2010 is a bit &^%#^*.
The change oil message came up, showing 5% remaining.
I checked my logs and only have 1200 miles on this oil.
I don't drive as much and I know the "short trip" factors into this.
My last change was in Oct of 2011. I reset the counter then as I do all my oil changes myself. The truck sits for days at a time in my basement.
I will not be dumping 7 qts + a filter, the oil is very clean on the dipstick.
I guess it is a $$ idea Ford has for the dealer's Quick Change dept.
Old Jan 31, 2012 | 01:20 PM
nards444's Avatar
i think that thing factors in time
Old Jan 31, 2012 | 01:54 PM
Yes, it is a time factor, coupled with short trips. If you hardly drive the truck, put it on a 6 month change interval if you use conventional or semi-synthetic oil.
Old Feb 1, 2012 | 11:27 AM
shotgunz's Avatar
What &^%#^* algorithm do you speak of? The one detailed in your manual and maintenance guide? Have you read either of those &^%#^* documents?
For the 09-10 it's 7500 miles or 6 months whichever occurs first.
Old Feb 1, 2012 | 03:21 PM
The "algorithm" is what the computer uses to monitor the oil life. There's a lot more to it than a simple 6 months or 7500 miles, whichever comes first.
Old Feb 2, 2012 | 06:25 AM
shotgunz's Avatar
Not on the 09-10s. It's simple time or distance.
2011+, yes, there is an algorithm that involves load, RPM, speed, etc.
Old Feb 2, 2012 | 07:07 AM
nards444's Avatar
my 2007 chevy and 2010 camaro both seemed to use the driving habits to come up with a number, seems as if ford is just now doing that
