Minor corrosion on wheels
Old Jan 15, 2012 | 07:57 PM
#16F150's Avatar
Question Minor corrosion on wheels
Fellow Forum Members,
What do you all think would be the easiest way to remove minor corrosion on my KMC XD Series Black Matte wheels? Thanks in advance for any help.
#16F150
Old Jan 15, 2012 | 08:02 PM
2stroked's Avatar
Pictures?
While we're waiting, I'm assuming your wheels are aluminum. You also say they're matte black. Do you know what kind of finishing technique was used to get the matte black? (Powder coat, paint, anodizing, etc.) The reason I ask is that corrosion (more correctly called oxidation on aluminum) can generally be removed any number of ways. The bigger trick is going to be re-finishing the wheel so that you can't see where the oxidation was removed.
Old Jan 15, 2012 | 08:40 PM
#16F150's Avatar
Originally Posted by 2stroked
Pictures?
yeah they're machined aluminum and the more I think about it looks like oxidation.
Old Jan 16, 2012 | 01:50 PM
#16F150's Avatar
Gonna try some Gord's Aluminum Polish and Sealer and we'll see if that works.
Old Jan 16, 2012 | 07:32 PM
2stroked's Avatar
I think what you're going to find is that the oxidation is actually quite easy to remove via any number of means. The bigger trick will be removing a minimum amount of the matte black finish, then finding a way to protect the now unprotected surface. I will tell you this. Unless you totally remove the oxidation, it will come back pretty quickly. If you do completely remove it, you'll still have to apply a new protective coating. Paint, powder coat etc. are reallyu the only long term solutions. No wax or sealer that you apply by hand really does much.
