Trans Temp
Trans Temp
2011 eb screw ...just wondering what temps everyone is seeing from the trans... IMO mine are a little high but thats me ..... could you take a minute and share what temps your seeing after say a 45 minute drive .... mine are running from 192 to 199 on a 45 degree day... and the coolers are cold buy the radiator .... the inline valves i know opens at 186 degrees ....
2009 platinum with the 5.4
285.60.20 goodyear wrangler pro grade silent armors. on stock rims.( tires are way heavy, over stock.
edge cts shows constant highway running 172-185 thats with an outside temp of 40 here in illinois. running around town, stop , go stop. same outside temps a bit higher 185-190 or so.
in a hurry and heavy foot. the highest i have noticed was 204 , this summer and outside temp was 98 at least.
The 2011 6speed's all seem to run in the 190-200 range almost all the time. Mine stays right in the 195 range almost no matter what the conditions.
We had the hottest summer in TX history this year and it would be 195-197 in traffic at 113 degrees outside. This morning my drive to work it was about 48 outside and the temp was 194.
I'm late to the party but will confirm what has already been said. The trannys in the 2011s run hotter than the old ones did. I have test drove 4 2011s and own one. Every one runs 190-200 once it's warmed up. It doesn't matter if 30 or 115 outside that's what it will be.
