HBS leveling kit
Old Oct 25, 2011 | 03:33 PM
88mack's Avatar
HBS leveling kit
Long time reader first time poster. I saw TXST8tj post on installing a leveling kit that looks like a great help. I have an '09 though and hear they are more difficult to install. Any truth to this? Anything you can advise would be appreciated!
Old Oct 25, 2011 | 03:51 PM
NASSTY's Avatar
I installed 2" Autospring leveling kits on my 06 and my 11 and it's basically the same installation procedure. The only difference is it's harder to get the shock w/spacer back into place on a 09+. On my 06 the shock w/spacer went right back in. On my '11 (as per Autospring's instructions) I used a bottle jack between the lower control arm and the upper shock tower and the shock w/spacer went right back in. I tried it first without a bottlejack and it was a no go.
Old Oct 26, 2011 | 12:45 PM
hydro1's Avatar
don't the newer trucks need the battery disconnected when installing leveling kits as to not damage the electronic steering??
Old Oct 26, 2011 | 03:03 PM
NASSTY's Avatar
Yes, the 2011's do. But not the 6.2's, they have hydraulic power steering.
Old Oct 27, 2011 | 07:12 AM
88mack's Avatar
Thanks for the input guys. Going to do the install today!
Old Oct 27, 2011 | 05:50 PM
2004f1505.4x4's Avatar
Put the HBS 2" in my 2011 fx4, not really easy but it is possible
Old Oct 31, 2011 | 08:53 AM
88mack's Avatar
Complete!
Thanks for all the comments on the lift. I have very little mechanical savy, but had no issues what so ever with the lift. I completed it in about 2 hours and used tools from around the shop. The best advice was using the jack to lift things up and into place to reconnect.
Ill try to post the before and after.
Thanks again for all the help!
Old Oct 31, 2011 | 09:20 AM
88mack's Avatar
Cant get the pic to upload on the post but added to the garage if your interested.
Old Oct 31, 2011 | 09:44 AM
06yz250f's Avatar
looks good.
Old Oct 31, 2011 | 10:07 AM
redelsinore's Avatar
Can someone explain this disconnectingn the battery before installing a leveling kit?
I installed my AS kit without disconnecting my battery, now what?!
