Which sr-a is the OEM tire?
275/65R18
Load Index 114 = 2640lbs (1200kg) per tire
Speed Rating “T” = 118mph (190kph) 114T SL Treadwear: 500
Traction: A
Temperature: B500 A B 2601 lbs.
44 psi
13/32"
39 lbs. 7.5-9.5"
8"
11"
8.2"
32.1"
or
275/65R18
Load Index 123 = 3472lbs (1578kg) per tire
Load Index 120 = 3169lbs ( 1440kg) per tire
Speed Rating “Q” = 99mph (160kph) 123/120Q E Not required for
this tire.None 3415 lbs.
80 psi
49 lbs. 0-0"
8.5"
Traction: A
44 psi
13/32"
39 lbs. 7.5-9.5"
8"
11"
8.2"
32.1"
or
275/65R18
80 psi
49 lbs. 0-0"
8.5"
Not sure but I think P is for passenger vehicle and LT is for light truck. I also got the P275's. The LT's should look a lot more rugged. The sidewall should be stronger on the LT's.
The construction of the LT version of the tire is going to be more robust, thus heavier, a firmer/rougher ride and a bit higher price.
If you've never run LT tires before, be aware, the ride difference between P and LT is fairly significant. I noticed when I changed tires on my old '04 to LT from P, the ride was a lot stiffer.
I'm now certain that I'll go with P tires this spring when I get new ones!
I like the smooth ride when empty.
