Changed front marker bulbs.
I know it has been done here before, but I grabbed a set of chrome 3157 marker bulbs off ebay, and got them in. A few pics.
Before.
one side done, one not....
Finished result.
The bulbs, pic borrowed from ebay listing.
And finally, the listing itself.
http://www.ebay.ca/itm/ws/eBayISAPI....E:L:OU:CA:1123
Yes, they light up orange.
Before.
Finished result.
About a month ago. I also painted my wheel opening mldgs. Next up, turn the chrome running boards blue.......
Did you have to remove anything from the lights or is it just the orange bulbs that gave the housing an orange tint? I think it looks good with the whole headlight clear instead of 3/4 clear 1/4 orange
Gawd. This is absolutely AWFUL.
I can't BELIEVE it you did this.
I mean, I've NEVER, EVER stumbled across a MOD and "said, OMFG..."
"...I GOTTA git me some of those," and head straight to eBay and buy them immediately.
You SUCK.
You SUCK.
I have no idea how to take this. Do I give ya the finger, or a thumbs up. Either way.... I salute you.
if the parking or all lights were not "on". and i would turn and or brake. the switchbacks upfront would light up white. becuase the two wires are internally connected with the internal electronics in the bulb itself. it would backfeed, even more so because the smart junction box holds everything above ground when that ckt is not on. i wish i also had the switchback fog lamps. you would definatly be seen when turning with those.
also - depending on personal preference. you might want to install load resistors at some point in the ckt, up front there is more room. this will slow down the flash rate. there is still a definate on-off-on. so i didnt worry about it. cop friend said they were fine. but even he would check to see if fronts were burned out , and initiate a pull over if it was warranted or if a reason were needed. !
www.v-leds.com
everyone have a good week.
I am already in the process of changing some of my bulbs out to LED, but really want Plug-n-Play. From what I've read, most of the replacement LED retrofits already include load resistors, if necessary.
Never heard of the SwitchBacks myself, but I just Googled them and they seem interesting.
The reason I'm sticking with these "chromed" bulbs is that I have clear dual projector aftermarket headlights and these bulbs would look better in them during daylight since they would be very easy to see through the clear lens.
For other housings that obscure the LED's, I will switch to LED's.
